RCU Forums - View Single Post - 4 Star 60 build question
Old 02-19-2011 | 05:34 PM
lamarkeiko
Default 4 Star 60 build question
<span style="font-size: larger"><span style="font-family: Comic Sans MS">I have completed building my wing with the rounded wing tips, and also thefuselage enough to check the fit of the wing. I have never built a low wing plane before, so I'm not real pleased at the fit and what I thinkisanexcessive gap where the curved leading edge meets up on the fuselage. I don't know if that space is suppose to be taken up by wing saddle foam tape or if I should make up a filler with some epoxy. There is also an unsightly space between the rear of the landing gear plate and the leading edge of the wing. Should this area be filled in with some wood stock glued to the back of the landing geer plate? Any advice on these issues will be appreciated. I will post some pictures if I can figure out how to do that.
Lamar</span></span>
ID:	1566697   Click image for larger version
