RCU Forums - View Single Post - Fan Trainer Order problem
Old 02-20-2011 | 09:35 AM
crashtesting
Default RE: Fan Trainer Order problem
Thank You for your response. I live in Northern California so going there is not feasible. I received back the e-mail that I sent to them as it could not be delivered. I've tried to call, and the message system was full and did not take my calls. I am at a loss to what to do. After going over everything closer, I found the rudders beveled edge is very off center. It binds going to one side. The holes are not pre-drilled in the fuselage for the rear fuse to bolt on to. No holes are drilled for the wings rear alignment dowel which sets the incidence. If there not drilled correctly, it will not fly correctly. I'm sorry for sounding whinny but I am meticulous and a little anal about my planes. I have pictures but I cant figure out how to post them. I tried to upload them but was unable to preview this post with the pictures. Any help? Please.
Thank You Very Much..............Fly-On
ID:	1567018   Click image for larger version
ID:	1567019   Click image for larger version
ID:	1567020   Click image for larger version
