RCU Forums - View Single Post - Still can't get split elevator to work
Old 02-20-2011 | 01:39 PM
goirish's Avatar
goirish
Default RE: Still can't get split elevator to work
here is what Horizon hobby sent me for instructions
Thank you for contacting Horizon Hobby Product Support.
To set up duel elevators you will need to perform the following:
Input Select Menu: INH the AUX 2
Program Mix 5 or 6: MIX Elevator and AUX 2
Rates +100 up +100 down
Plug the right elevator in the elevator channel and left elevator in AUX
2 port on the receiver.
How do I get to the input section to INH Aux2? I can get both sides of the elevator to go in the same direction. Problem is: they both go down the same, but one will only go about 1/2 of the way up compared to the other side.
