RE: BVM LE flap.
Hi,
The BVM kit had a molded resin inlet lip with the kit. I've used that molded piece on several Yellow Falcons. It's not an exact fit since the shape of the two inlets are different but you can heat it up and bend the edges a bit. I don't know how much of a difference it makes, but it sure sounds a bit different. I imagine it helps on the Yellow.
