RE: ASM P-61 kit Build
Completely dismantle them and make sure the spacers and washers on the two side to side tie bars are equal lenghtn and that the hole all align OK. Ihaven't done this yet with mine, but things look better from the start. One think Inoticed is that the mouning holes are different on the mains from the first set. HUmm, just noticed the the air fitting on the dead end of the cylinders is a 90 degree fittinv vs the straight fitting from eariler which was pointed out as a tank clearance issue early in this thread.
I'm about ready to start on mine. I had been holding off as I didn't really have a way to transport it to the field. Just before Xmas, I found a good buy on a not very used Chev Uplander Cargo van, so no more reason to hold back.
Don
