RCU Forums - View Single Post - Antenna Wire
Thread: Antenna Wire
Old 08-10-2003 | 10:58 AM
EC120's Avatar
EC120
Default Antenna Wire
You can buy 35 feet of it at RadioShack for less. I replaced one with 24 gauge stranded wire. The wire is the same and the protective coating is just a little thicker. If possible, dont get into the RX box but splice it with the antenna already sticking out. That will help isolate the heat from the electronics when you solder it.
