RE: KingTech K-80
Hi Justin, i am Justin also so lets not get confused.
Have you checked the pwm rate for the fuel pump? if the start rate is low enough it wouldnt have time to ramp up in time, but it would be very low to cause that. sounds like the pump is good but how much flow you have is the question. If the fuel is flowing into the line at startup then it may be a different problem alltogether.
You dont by any chance have the lines reveresed in the quick commects, i.e. kero line in the propane and propane in the kero by any chance?
Regardless, you best option is to give Barry or Todd a ring, very knowledgeable and quick to help.
Thanks , Justin Malone<br type="_moz" />
