RCU Forums - View Single Post - KingTech K-80
Old 02-20-2011 | 08:07 PM
  #422
JLink125
Default RE: KingTech K-80
Yeah lets not get confused, I'm Justin Link. Fuel and gas lines are correct, it will run on the propane but when it goes to fuel ramp I noticed that no fuel is flowing into the engine, I do have a ball valve on it but I made sure to open it prior to starting. What rate should it be at? I'm running a box stock setup so it's set at whatever the factory put it at, the pump seems weak to me though, when I initially tested the pump to fill the line it took quite a while to suck up anything then when it finally did it moved pretty slow to the cup I was draining into.
