RCU Forums - View Single Post - KingTech K-80
Old 02-20-2011 | 09:25 PM
  #424
jmalone1982
Default RE: KingTech K-80
this unit, where did it come from?
Also what fuel pump is on it? If it has a black fuel pump, its a stock kingtech unit, while if its a flightworks unit it will say so on the unit.
the settings look like it should run so im not sure. i have seen a few fadecs go bad from extended pump testing. If the pump was slow to start and pumped poorly you may try breaking it in but i just dont trust a questionable pump.
time and time again i trace problems back to the pump.
