RCU Forums - View Single Post - What's too hot?
Old 02-21-2011 | 07:50 AM
smcharg's Avatar
smcharg
Default What's too hot?
Hello all,
I'm fixing to move and the only place that I have available (at least for a little while) to have my "workshop" is the garage to the house. I've received permission to make this into a workshop with a TV and carpeting and the works. I have several pattern planes from old school LA-1 era to the 2M pattern ships and foam F-16's and built up Edge 540 and the likes. Ilive in Texas and the summer temps are usually in the high 90's but the humidity is also around 90%. I have the garage door insulated with foam which will help but the garage is not air conditioned and a swamp cooler isn't going to work here. Is this too hot?
I've always stored and worked on my planes in a temperature controlled environment and, although I have several friends that keep their planes in non-A/C workshops, I always worry about the foam core wings warping and the fuselages twisting and the sort. Do y'all see any problems with doing this? Once the garage is transformed, the garage door will not be opened unless it's just a crazy nice day. Will my lipo's be OK also?
Just trying to get some opinions.
Scott
