RCU Forums - View Single Post - GP .40 Lear Jet build
Old 02-21-2011 | 12:09 PM
kargo
Default RE: GP .40 Lear Jet build
I have used a robart drill jig, hinge glue and petroleum jelly for the hinges on my sig senior. After drilling the initial hole i used a dremel conical sanding bit to widen the drilled hole (control surface only) a bit so the "knuckle" of the hinge would sit inside the control surface, this prevented a large gap. The petrolium jelly prevents glue from gumming up the hinge, and the hinge glue is a aliphatic resign (wood glue) sold as hinge glue. I'm not sure if there is a special difference between it and regular wood glue. I couldn't find a link, got it at my lhs...
Maybe someone who knows better than i could pipe up. I really like the robart hinges, and the process of installing them. Good luck.
http://www3.towerhobbies.com/cgi-bin...?&I=LXET65&P=7
