RCU Forums - View Single Post - Dumb question re flaps
Old 02-21-2011 | 01:51 PM
Ed_Moorman's Avatar
Ed_Moorman
Default RE: Dumb question re flaps
I think flaperons and spoilers are great to use on a Stick of any type. I've used them on Big Stick 40, Ultra Stick 40 & 60, Wild Stik 40 & 120, Joss Stick, Little Stick.
I set the flaperons to move opposite to the elevator for tighter maneuvers. These are great for downward outside loops and outside square loops. It gives you enough control authority so you aren't afraid of hitting the ground.
For landings, I use about 15 degrees spoilers (flaps upwards) mixed to throttle so the spoilers start to deploy at half throttle and are fully up 15 degrees at idle. This keeps the Stick from floating and makes for good spot landings. As you add power, the spoilers also drop down slightly, increasing your float. When you throttle up for a go around, they drop to the normal aileron position.
