I've had a 10,000 btu a/c in my garage for 25 years and it works great. I just bought a wall unit from Sears. It's been a long time, but I seem to recall buying an optional hanger from Sears to use when wall-mounting versus window mounting. I just followed the instructions, cut the hole to size, and mounted it. I put a good bead of silicone caulk around the outside where it protrudes through vinyl siding and never had to touch it since. I have a very well insulated (by me) 2-1/2 care garage with a drywall ceiling and paneled walls. The 10,000 btu is just big enough. I wouldn't go any smaller and a little bigger would be okay. I mounted it high up on the wall to discourage thiefs from knocking it out as an entry point and also to distribute the cool air which is naturally dropping as soon as it comes in. I only run the a/c when I'm doing something out there in the summertime. The garage will always be a little cooler than the outside temp if you keep the door closed. I live in Michigan and we get our fair share of 90 degree days here too with brutal humidity. I'm sure we're a little cooler than Texas on average, but I don't think you'll have any problems.
Verne
ORIGINAL: CLRD2LAND
Hello all,
I'm fixing to move and the only place that I have available (at least for a little while) to have my ''workshop'' is the garage to the house. I've received permission to make this into a workshop with a TV and carpeting and the works. I have several pattern planes from old school LA-1 era to the 2M pattern ships and foam F-16's and built up Edge 540 and the likes. I live in Texas and the summer temps are usually in the high 90's but the humidity is also around 90%. I have the garage door insulated with foam which will help but the garage is not air conditioned and a swamp cooler isn't going to work here. Is this too hot?
I've always stored and worked on my planes in a temperature controlled environment and, although I have several friends that keep their planes in non-A/C workshops, I always worry about the foam core wings warping and the fuselages twisting and the sort. Do y'all see any problems with doing this? Once the garage is transformed, the garage door will not be opened unless it's just a crazy nice day. Will my lipo's be OK also?
Just trying to get some opinions.
Scott
