RCU Forums - View Single Post - New Electronics?????
Old 02-23-2011 | 06:17 PM
philipat
Default RE: New Electronics?????
ORIGINAL: Fireman Tim
I have some more information regarding use of the programming remote. (Remember we are translating these instructions from Mandarin...If I got any of this wrong I am sure Hulu will correct me.)
You can use the remote programmer to set your ammunition level between 20 and 120 rounds in 10 round increments, or you can set it for unlimited.
You can also decrease the receiver sensitivity range in 10% increments. So you could set your JagdTiger to only take hits at say 30% of the normal range.
The third application you can use the remote for is setting the tank to auto restore after it is destroyed, or for manual restore using your remote controller.
Now once you have set these parameters, you can save them to memory.
Small interjection for the airsoft crowd...
Looks like we wouldn't need the controller or the battle unit. It appears that there isn't any programming necessary for an airsoft tank. Just plug the airsoft unit into the same spot as the recoil (if using IR &recoil) and you're up and running. Correct?
Also, would you have to buy a tank-specific SLU? Meaning that the sounds are not programmable. I couldn't take the SLU from a Pershing, reprogram the sounds and put it into a Tiger...or are the sounds stored on something like that a micro SD card that can be replaced depending upon the type of tank that it's placed into?
