RE: Fokker D.VII 1/4 Balsa USA
I do like to fly scale and that good enough for me. So I'm going with the Saito G36. I have heard that Saito's require 91 or high octane fuel. My manual states to use regular. Anyone know for sure?
Here are some more progress photos.
I'm almost finished with the upper wing. Here in the photos I have completed the push rod guides and installed the servos. Also the servo trays are complete. They are a little large however, I need to be able to get my fingers in there to perform any adjustments.
I have covered the elevators and rudder. Going to cover the Horz and Vert. Stab. Then off to finish the guns and cockpit.
The cockpit kit (several mini kits) have a ton of tiny parts. All are 1/4 scale and I bought them from GTM (Glenn Torrance Models). You might have seen in other photos the the floor and that is a kit from GTM. A little cutting, staining, sanding and gluing and that's all.
