ORIGINAL: eddiemans Have tried to set up telemetry in 100" gasser with sensor station in cowl as the temp & rpm sensor leads are short, with extension leads back to receiver, however, No Sensors Fitted displays when I try to look at whats happening. Plugged sensor station direct to receiver & no problem. Tried different extensions, etc. all to no avail. Can someone please tell me if there are specific extension leads for either the sensors or data lead to reach approx. 18" back to the receiver or forward to the sensors.
Telemetry - Instruction Sheets & User Guide with pictures <font size="1">plus Enhancements Under Development</font>.
<span style="font-size: smaller">".6.
Extension Leads.
. <font color="#22229c">Optical Sensor, with DIY extension, attached Heli tail</font> <font size="1">pictures x 3</font>
<font color="#22229c">At the present time, there are no extension leads for the telemetry units.</font>
...."The stock length of the RPM leads are supposed to be
<font color="#22229c">longer on the next batch</font> but extensions are needed in many cases although this should help. Temp leads can become inaccurate (I've been told) if they get much longer but I don't know to what extent.
There is an extension <font color="#22229c">offered here</font> that would work with the RPM sensors for now.- Mike"....
<font size="1">in case Horizon as usual blocks direct link = SPMA2001 6-inch Ultra Micro Extension "
<span style="font-size: x-small">
Data cable wiring is not standard, refer pictures attached above link.
</span></font></span><span style="font-size: x-small">
Alan T.
Alan's Hobby, Model & RC FAQ Web Links</span>
