RCU Forums - View Single Post - Engine Idle Issue
Old 02-26-2011 | 06:34 PM
yf222000
Default Engine Idle Issue
Hi all.
I am wondering if the experts here can help. Long story short, after a crash, my YS 120FZ was repaired by me. However, most of the gaskets were intact, so I didn't have to replace any. After a long while of sitting once repaired, I tried to start it today using wildcat 20-20. It wouldn't start. I had to drop fuel into the carburetor to get to start. Once
it did, it will not idle at 2000 RPM as it used to before. Once started, it jumped to anywhere from 4000 to 5500 RPM, and surges up and down. Sometimes it drops down to 2200 RPM, then it either stop running or surges back up to 5000. I had checked the throttle linkage and setting for idle on the engine itself, all is fine. Would it be possible there's air leaks, or gasket leaks somewhere to caused the engine to idle so high and surges like this? Thank you for all the inputs.
