RCU Forums - View Single Post - KingTech K-80
Old 02-26-2011 | 06:46 PM
  #433
jmalone1982
Default RE: KingTech K-80
Okay guys, especially Todd and Barry. Got the unit set up for test, K80 e. Ready for the first start, step one - tx learn. well ecu wont learn anything. When trying to go through the tx setup proceedure, I cant get the fadec to recognize any throttle position.
By going into the second screen menu the signal reads 0000u and 100%. You know whats going to happen when it starts at this setting?
Checked out the radio. futaba 10c, checked both normal and reverse servo direction , and also plugged in a servo to the throttle port.
transmitter also works with all my other rx's and planes. Bad ECU? Bad Luck? Let me hear something good.
If you have the connections installed into the turbine and all leads plugged in the unit will attemp to start directly after you just cycle the screens in the tx learn menu. Consequently, If you dont have throttle channel control you cant stop the startup procedure.<br type="_moz" />
