ORIGINAL: jmalone1982
Problem with ecu was a broken signal wireinside the pin, a freak accident no doubt an easy fix, but the pump , not so easy.
Jmalone.
One more thing you might want to check. With Futaba and the ECU, You need to set your throttle travel adjustment or I think Futaba calls it ATV to 125%. Relearn the transmitter and give it another start. I understand the pump issue to and Barry will make it right for you.
Joe Lewis
Kingtech
K-80 owner
