RCU Forums - View Single Post - SdKfz 250/9 project
Old 02-27-2011 | 01:50 PM
  #60
CountChocula's Avatar
CountChocula
Default RE: SdKfz 250/9 project
Using the paper templates, I traced then cut out the pieces using .060 styrene stock. I then CA's them to the turret base plate. It's a little rough at this point so filler will be needed along with some sanding etc. But it gives an idea of the overall size of the turret when setting on the body. Due to all the angles, I went with the 6 sided turret (which was more prevelant on the "neue' body anyhow since it was easier to manufacture) instead of the 8 or 10 sided version on eariler models.
ID:	1570899   Click image for larger version
ID:	1570900   Click image for larger version
ID:	1570901   Click image for larger version
