RE: JR 12X Programming Question
Joe and Craig,
Thanks for the input on programming the 12X to couple ailerons with elevator.
After much frustration, I called Horizon to get their take on how to do the mix. As I said in my first post, I was in the "Normal" mode in wing type. I had mated R Ail w/ L Ail and also mated R Elev w/ L Elev. This was the problem. First they had me unmate the two Elev halves. Then mix R Elev+ to L Elev in my first mix. The second mix was R Ail to R Elev. Then L Ail+ to L Elev. I had to play around with the +100 and -100 to get the throws going the right way. I set the elevator throw to 50 % and will adjust it based on the sensitivity in turns and rolls.
When you see how its done it doesn't seem that hard. I suspect I wasted 3 or 4 hours before giving up in frustration.
THANKS HORIZON!
Rob
F15driver
