RE: Servo
use a reciever/battery you know works, then start testing one servo at a time, could be a bad batt that cant handle the draw, could be bad reciever. if it seems like the servos are the problem test them on something you KNOW WORKS like a setup from another plane....if you have the same problem the servos are shot...if not get back to us.
im wondering if it could be a bad switch as well....try bypassing that
