RE: Miss Geico 29 Catamaran
Hi Guys,
Total newbie here. Have got planes, etc... but the MGwill be my first FEboat. Boat should be delivered tomorrow, tracking says it's in the country (New Zealand). I've read all I can absorb here and on OSE and have the following to set the boat up:
Kintec V2 offset rudder bracket.
Kintec replacement flex shaft
5.5mm castle bullet connectorsand some 10 gauge wire. I'veread on OSE how to make the parallel connectors.
x642 s/b prop from OSE
Proboat ESC programming card.
I will strengthen the hatch with 2oz glass cloth.
What batteries are recommended for good speed but won't blow the stock gear, I'm thinkingtwo 4S 5000mah in parallel. Your comments?
Also what settings should I use on the ESC programming card?
Many thanks,
Gordie.
