RE: Sebart Wind 110
Ok, motor mounted! I used 4x10 mm button head socket bolts...perfect!
All I have to do is hinge the ailerons and install the aileron servos. Then it is just a matter of connecting up the RX...
I do have a few questions for you guys that have your Winds in service. First off, the landing gear fairings, what method did you use to attach them to the gear struts? What glue did you use? Has the glue held up?
On your batteries, what connector is everyone using? Deans plugs? Powerpole?
Anything else you guys want to mention?
Thanks!
