RCU Forums - View Single Post - Tamjets Smoke System
Old 03-01-2011 | 04:47 AM
VF84sluggo's Avatar
VF84sluggo
My Feedback: (55)
Default RE: Tamjets Smoke System
Thanks Tam.
Question: I think I read a post somewhere about using only one smoke tube/spray bar. The reasoning was that one bar will give enough smoke, and will not use up the smoke oil as fast as having two smoke tubes installed. Supposedly this will allow for more 'smoke on' time. Is this true? FYI, I am using this system with a Jetcat P-70.
Also, it is going to be impossible for me to keep the smoke pump 6 inches away from some type of electrical device, as is recommended by the instructions. I can get it away from the ECU and RX antennas (R6014HS rx), but a battery and servo leads will be less than 6 inches away. Is this going to be trouble?
