ORIGINAL: VF84sluggo
Ok, looks like I've got my work cut out for me trying to find a good spot for the pump. Is 6 inches from a battery crucial?
No. Tam's recommedations are very conservative. I suppose there may be situations where it might make a difference but I've seen these pumps put in all sorts of locations and it doesn't seem to make much difference. Take a look at one of his pumps in my KingCat....close to lots of stuff and wires running everywhere with no problems.
Just make sure you do a good range test while switching the pump on/off.
FYI, I might suggest a seperate battery. It only takes a size AAA 6 cell/720 mah for a days worth of flying. Keeps the smoke system completely separate from the other electrics.
Craig
