RE: Top Flite B-25 ARF (Tecnical, tips, suggestions)
It is the 401 gyro from Futaba. The delay is zero I believe. The only time I've heard of some guys using HH for airplanes is on takeoff to keep it absolutely straight down the runway. Upon wheels up, you would switch to rate before any turning is attempted.
Not sure how I ended up at 85 and zero. The rate mode doesn't seem as sensitive as I would like it so I want to change the zero value. Just can't remember if closer to 50 is more sensitive or closer to zero.
