RCU Forums - View Single Post - Sebart Wind 110
Old 03-02-2011 | 03:04 PM
  #1423
rcpattern
My Feedback: (45)
Default RE: Sebart Wind 110
ORIGINAL: david hancock
One other quick question. I am running 2 500 Mah Lipos for my receiver and servos. Is this sufficient power. I am running them through one of the dual regulators (PLR 5-DR2) that Ed Alt sells. One more. I mounted the motor with 4 M4x12mm screws. Is this and the rear bearing support all that holds in the motor? Thanks for any help sent my way. Dave
David,
That is probably even overkill. I run dual 350mah packs on my 2m Wind and can comfortably get 10-12 flights. You should use around 30-40mah per flight total, so only about 20 or so from each pack. With the lack of vibration on the electric motors it is amazing how little the servos have to work,
Arch
