RCU Forums - View Single Post - Nose dropping won't stop
Old 03-03-2011 | 10:02 AM
johndou
Default RE: Nose dropping won't stop
Do you have the trim set properly? Your plane should fly straight and level (hands off) at about 3/4 throttle. The trim will need to be set for each airplane (or heli) you fly. If you have to hold up elevator (or down) to get your plane to fly straight and level at 3/4 throttle, then you need to adjust the trim.
