RE: Nose dropping won't stop
After reading all the preasent posts, I am wondering if perhaps the problem is in the sim program itself. Ocom's razor says it quite well, "the simplest explanation is most likely the correct one". If you've checked and re-checked everything else and can't find a fault, the only thing left would be the sim program itself or program compatibility with the computer it's being run on.
