RE: Sebart Wind 110
The Futaba 9650's has additional mounting tabs molded into the case which is not going to allow installation into the stabs without removing them. For those who used this servo with the Wind, did you need to remove the tabs? I hate the thought of taking a dremel to a new servo and there is not enough mounting surface in the stab to cut away to make room. How did you go about mounting them?
Thank you
