ORIGINAL: FlyCrashRebuild
Has anyone tried/seen the Gorilla Glue Super Glue, supposedly it is rubberized to be less brittle?
I've been searching thru the threads and it seems CA is the primary glue of choice.About 10 years ago the old timers I was around didn't have much good to say about it and I was encouraged to use Duco cement (it's in the green and yellow tube). Has this stuff really proven itself to have longevity. I am starting to get back into building and was wondering. I know it's a quite the debate, but what do you guys who have been building for40+ years think.</p>
Hello "FlyCrashRebuild"
I wish your name would be "FlyCrash and make minor repair".
There isnot many participants in this forum that were building model airplanes more than 40 years ago.
That puts people building in the 1950s and 1960s.
We were using aliphatic type glues or similar. I have models glued with the type of glue used in those days to cement floor tiles to the floor. As a club in those days we would buy a five gallon can and spread it around the group each having about a couple of quarts of glue. It lasted a long time.
With thin CA there is not enough solid material left after cure to make a strong join so in a crash there is dozens of pieces. I will refrain from any comments why CA is so highly recommended these days. I simply will not use CA else than for tacking followed by proper gluing technique.
Zor
