ORIGINAL: Sturmgewehr
ORIGINAL: shenlonco
better yet get liquid model solvent and drip some into the crack and let it dry and it will melt it back together again.... do some weathering some mud and you won't even know it was ever there.
[8D] And yellowshaker said I also agree.... Phil @ RCTANKWARS!!
Never heard of that, can you shoot me a good source for the solvent.
Dominique at RCTankDE is my #1 guy.
go to your local hobby shop and ask for ambro pro weld it is the solvent for styrene and will fix you hull as good as new
do not use CA to fix the hull it will not glue the crack shut styrene solvent will melt the plastic back togeter making a strong joint as good as new and it can then be sanded smooth and you will never see the repair one finished
