RCU Forums - View Single Post - Wing Sanding
Thread: Wing Sanding
Old 03-08-2011 | 10:23 AM
Gray Beard
My Feedback: (-1)
Default RE: Wing Sanding
I have bars I made in several lengths, most often used is the 11 inch and the 6 inch. Grit most often used???? Depends on what I'm sanding. I make my bars by running hard wood blocks through a plainer and use contact cement to glue down the sand paper onto the block. Some blocks have different grit on each side. When the paper is dead the bars are a toss and replace.
