RCU Forums - View Single Post - Power supply
Thread: Power supply
Old 03-08-2011 | 03:19 PM
Swift427's Avatar
Swift427
Default RE: Power supply
As a 'general' middle-of-the-road AC wall outlet (12VDC 4-5A) charger should suffice for most parkflyers. Always better to get more amperage than you need. Even though you may never be charging anything with more than 3300mAh capacity you need the extrp cushion so it doesn't overheat during 60 minutes of charging.
http://www.google.com/search?sclient...Bw&safe=active
ID:	1575556   Click image for larger version
