Tailplane failure on a Glens Extra 58"
ok here is the best pic I have at the moment, my digital camera has been loaned out to a friend so it will be a week or so before I can get a better pic for you.
In the pic you can see the brackets and the bolt that passes through them to hold the two brackets together. One end of the wire is just looped through the bracket and crimped with a small piece of brass tube, the other end is attached to a closed loop adjuster to allow tensioning.
Chris
