The final CG check before a flight test (when weather allows). CG is 90mm with an empty tank.
The struts are made from scratch from these light aluminum tubes. I use JB Weld & epoxy.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXR855
The weight of each strut is around 45g. .
