Hi everyone
OK I bought thicker oil for my shocks and because I couldn't find springs for my Truck I'm also using pre-loads.
Seem's to have done the job but one side of the spring is quite low with the combination of using my already fitted adjustable shocks and adding pre-loads to make it go higher, doesn't really bother me but I was thinking ideally does anyone know what brand springs will be compatible for my Truck, obviously I need stiffer springs.
I bought a pair before but the size meaning width and length was all wrong, although they were Hard in strength when compared to my stock springs they seemed pretty much the same in strength.... so I am thinking I need Super or Very Hard Springs.
The problem I am facing is the stock springs are and correct me if I am wrong 70mm x 18mm part #60002 and basically I just can't find Super/Very Hard Springs that are compatible so if anyone knows which springs I should be looking at please give me a heads up.
Thanks in advance
