RCU Forums - View Single Post - Trouble getting motor to run
Old 03-11-2011 | 07:21 AM
kc5dlo
Default RE: Trouble getting motor to run
I was able to get the motor to run last night. I found a generic file for fixed wing to load into the transmitter. Still need to go back and revese the servos in the transmitter as the throttle stick was backwards.
Does the servo direction have anything to do with the way the cable is plugged into the receiver? Could not find any direction to plug them in so I gust made sure they were all facing the same direction. Worst case I would have turned the plugs around. It is quiet easy to simply put a check mark in the box to reverse the servo though.
Lots to learn. Thank you all for the help.
Steve
