RCU Forums - View Single Post - Servo torque question
Old 03-11-2011 | 08:33 AM
Stoneke
Default Servo torque question
My wing flaps (three separate sections) on my Byron AT6 are controlled by a single Futaba S3302 servo. The center section of the flaps is the one that is connected to the servo and this section retracts to a nice tight configuration to the fuse. An outer section droops down about a 1/4" when retracted. I am able to bring all sections up tight via the tx adjustments, but then the servo buzzes.
Question: 1. Would a higher torque rated servo be able to answer the additional force without buzzing? 2. If so, what size would be recommended?The Futaba S3302 is an 89 oz/inch servo.
