RE: Servo torque question
Jetmech & Airbusdriver are absolutely correct if your servo is is stalled at the up position then trying to force it up even more for the outers is no solution.
You must fix the problem mechanically convenient or not if having the outers hang down is unacceptable.
Change or modify the linkage or better yet just secure the flaps in the up position permanently.
John
