Making Z bends in control rods
Finally what I did was to find a metal plate about the same thickness as a servo horn and to drill a hole in it slightly larger than the pushrod. Then I made an initial bend of 90 degrees in the push rod. Then inserting it through the hole in the metal plate i could then bend the part sticking through flat to the plate making a perfect z-bend. see picture
