Another option is to use a rod threaded at both ends with a clevis on each end. This makes adjustment easy from either end of the rod.
Do Not do this. There is a danger, however remote, that the push-rod can turn in the clevises and alter its length. If this happens in flight the results are obvious. In the event I fly this is illegal, we have to have zee bends at the servo,
Ed S
