RCU Forums - View Single Post - what size engine
Old 03-11-2011 | 05:15 PM
Gray Beard
My Feedback: (-1)
Default RE: what size engine
ORIGINAL: ameyam
Its a fallacy that the 40 sizers need a 46 or 55ax. A colleague at the field is flying a 40 size 60'' span trainer with a 35 size 2c and it can do all the aerobatics that a trainer can do and more. You just need to prepare a bit earlier (give throttle earlier) so you have airspeed to finish the move. Limited to just sports flying of course. If you want 3D, some will say even a 75 will not be enough (airplane being suitable ofcourse)
Ameyam
Read Johns post about his SK and the .35. I have seen several of these planes with a .46 and the .46 had gobs of extra power. I once flew a glassed and painted 40 size Supersportster with a .46la, it flew the plane but there was no OS factor at all in it. That was a very heavy plane I bought at auction. There is still a big difference between flying the plane and getting it off the ground. If I have to dive a plane to do a tight loop then it is under powered. The OP is looking for good performance. That is an opened term but a good .46 should do it in most cases. I look at good performance as being able to pull a plane from straight and level flight at half throttle and being able to roll power on as needed to perform a giant sky filling loop. I'm talking a big loop, not a tight little over the top loop after a dive.
This brings up the question for other pilots. How do you look at enough performance. I fly a very nice basic known pattern sequence with a 2 meter patterrn plane with a YS 1.20 engine. The plane should be running a bigger engine due to it's weight but it does everything I want and is really smooth. I feel it has very good performance.
