RCU Forums - View Single Post - KingTech K-80
Old 03-12-2011 | 02:38 AM
  #480
sandyjain
Default RE: KingTech K-80
ORIGINAL: marquisvns
Sandy, since you have two unused channels, why not use one of them for the other aileron for crow. A slightly exaggerated washout is most benefitial for this airframe (speaking from personal dreadful experiences, if you must ask), on slow flights, flatter rudder turns, or it would snap right out of the sky.... good luck!
Barry
Thanx for your suggestion Barry. However Ch9 & 10 are only on/off channels on the 10C not proportional.
Having said that - I can use those for the gear and brakes - hence freeing up Ch5 & 7, which are proportional ones.
The modified set up may look like:
Ch1 Aileron 1
Ch2 Elevator
Ch3 ECU
Ch4 Rudder
Ch5
Ch6 Aileron 2 , std. Flaperon set up on Futaba.
Ch7 Nose wheel slaved to rudder, activated by gear switch.
Ch8 Flaps on Y
Ch9 Gear retract on switch
Ch10 Brakes on slider or spring switch. My brakes are on/off not proportional.
In the above set up I can even have the flaps on separate channels to make trim easier.
What say you guys ??
