RE: Servo torque question II
The size of the flap servo.....ok look at it this way....if the servo you have is too weak then you won't be able to either put the flaps down or keep them down.....so put a load on the flaps with your finger once they're down and see if you can push them back up...
When it comes to servos always buy a bigger servo....My standard servo any more is a HiTech 5645.....Why...because you rarely go down in aircraft size....if you do then you have a servo that will work....ok if you go bigger then you probably have a servo that will work unless you're into giant scale.....
Did you plan on using a 6V battery?
