RCU Forums - View Single Post - 75ax on Reactor 46?
Old 03-13-2011 | 02:39 PM
jetmech05
Default RE: 75ax on Reactor 46?
I wonder...if the engine cuts out on you in flight.....and it is turned rich 1/2 turn from peak.....how is the cowling? is your air exit big enough...at least 2 times the entrance...3 times better.....sounds like you may have a heat issue.......
Is the 75 too much...maybe......depends on the weight and ground clearance for the prop
