RE: Bypass or Not?
if you do an open install, you can also use some fire resistant ceramic paint ( such as the BVM HeatShield) ... A this Stainless steel flashing could also be attached under the engine exhaust cone to protect the fuse from any oil / fuel that might drip out the rear of the engine ( such as after a wet start, or failed ignition )
~V~
