RE: 75ax on Reactor 46?
taching it is the only way you'll find out if the motor is up to par. compare it with other's rpm readings..... if i recall correctly i was getting close to 13k with a 13x4 apc using a modified stock muffler with out baffle, and drilled out stinger(exhaust tip) and cut it slightly shorter
