Warped wing?
Hi Ted,
I agree with all of ec121's advice. I would be most suspect of the warped wing if it is always dropping the same wing. You want the root to stall before the tip, and if you have negative washout, where the rear tip of the wing in "drooping" down a little, then the tip of this wing will stall first causing your problem.
